C
Carol
New to the game and it all looks different in the real world! I am about to upgrade one of the installation CU's which is CU1, CU2 is already new, but I have a quick question, I have a PME system, supply split at a Henley block to serve CU1 direct and secondly to a switch fuse isolator which then feeds CU2 via SWA to service an extension. The earth bonding to the switch fuse isolator comes from the MET in CU1. Should I firstly put an isolator switch in between Henley and CU1 and then install an external MET and connect to main earth supply and then feed CU1 and switch fuse isolator direct?
