Earth cable for water pipes | on ElectriciansForums
Discuss Earth cable for water pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Had to fit water bonding cable today, out through wall along exterior at about 7ft high and back into consumer unit area.
is the 10mm cable fine unprotected at that height or do I have to enclose it. Also, if it is fine up there, then does anyone know of any clips from CEF that are strong enough to go in the wall as it is hard, bent quite a few clip nails trying today. Failing that any 10mm screw in clips out there.
Totally forgot about pclips
brain fade
it is a rendered wall with big brick patten, struggle to get the nails half way in
will go the p clip route tomorrow.
Nail plugs or pin plugs. Little 'mini' wall plugs, drill hole (5mm bit x 20mm deep), insert plug then just use normal cable clip.
Once used you will never be without them!
They're life savers when the mortar runs are crap and you can't get clips in any other way.
They were fab last month when running cable across a concrete garage wall..!!
Reply to Earth cable for water pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
