Earth connections into new controller board | on ElectriciansForums
Discuss Earth connections into new controller board in the DIY Electrical Advice area at ElectriciansForums.net
Australia
Hi All,
I have 3 separate Earth wires connected into an existing controller board. These 3 wires all have ring terminals and were hooked to a single brass earth bolt connector on the board. Now, As I'm replacing this board, I realised the new replacement board only has one Earth screw terminal.
What are my options rather than striping the 3 ring terminals and connecting all into this 1 terminal?
Pics attached, the earth connection terminal on the new board is at the far bottom left.
[ElectriciansForums.net] Earth connections into new controller board
Hello, long time reader of this forum but never posted before.Just a quick thought that on the link it says that the connectors are for solid core conductors and the cores in the picture seems stranded. I have never used wago type connectors personally so not sure how they are with stranded cores.
Thanks for the heads up! will look at the wago for stranded cable. Cheers
the wago push fit suit 7 strand cable, but for fine stranded you need the 221 lever type.
Reply to Earth connections into new controller board in the DIY Electrical Advice area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
Looks like the new terminal block has a spare way for those three reds.
