Earth fault loop impedance | on ElectriciansForums
Discuss Earth fault loop impedance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
V
vmmila
Can somebody help me on how to test the earth fault loop impedance(Zs) of the following circuit Cooker,Immersion,motor .i have tried but the tester display :confused:
sounds like you are carrying out test incorrectly as amp says "what tester" but generally l,n.e connected and switch on unless calculating via Ze+R1+R2
Reply to Earth fault loop impedance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's the same with any system, if you put poo in, you get poo out!
When I did my AM2, I had it drummed into me that I had to follow Guidance Note 3 carefully. So, did you follow the guidance in GN3 for checking...
