A
AlanWirral
Hey Guys,
Just a quick one. Recently dealt with a problem at a relatives home in Anglesey.
Basically the polish maintenance guy got a shock off the outside water tap and then off the kitchen one! He turned the main switch off but it happend again:ack2:
I went along and with my voltstick started touching the metal light switches and taps and low and behold it lit up like a xmas tree. I quick polarity check proved my suspicions of an external earth fault.
I left the building and after getting in touch with Scottish Power they confirmed the 'Stay' on there mast had come into contact with the Line and caused the fault. This was rectified and the house was checked..Ze etc.
Now the owner obviously doesnt want this to happen again so i've said we need to fit a RCD. Bearing in mind the board is metal with only the rings protected by 30ma RCBO's and no main RCD. Is the best practice here to get SP to fit an RCD before the meter or should i go ahead and fit one after the meter and before the CU. Finding an old contactum main RCD to swap with the main switch might prove a struggle.
Haven't had the pleasure of dealing with this fault before so could do with some advice please boys :frown2:
Thanks in advance
Alan
Thanks in advance
Alan
