L
LouDog
Hello, I've been asked to replace an existing 185mm earth cable as it's a black HO7 cable that has been marked up with green/yellow heat shrink at intervals along its run and then fully once its entered an enclosure at each end. Client wants it green/yellow throughout its run. It's run in a cable pit under an LV panel through 1.5m of duct into another pit up to a distribution panel. I know the customer is always right, but does this require changing according to regs? Thanks
