Earth Leakage Device | on ElectriciansForums
Discuss Earth Leakage Device in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
haj
East Yorkshire
Hi Guys
My first job on a TT system quick look and me thinks it has 100ma RCD but am told its an early eath leakage device ?? and needs to be removed ? any of your valuable thoughts would be gratefully recieved:D
The were 2 types of old VOELCB's, one was black with a small yellow test button, tho other was grey with a long yellow test button.
These should be removed as they are of no use and probably dont work anyway.
[ElectriciansForums.net] Earth Leakage Device
Apoplogies if it sounds a stupid question - what should they be replaced with? A new RCD unit or a complete new CU?
These were used primarily on TT systems in the same way a 100mA TD is now.
A lot obviously depends on the customer and the existing CU. As a minimum they should be swapped out for an RCD, you could argue 30mA (if none present) but then that flies in the face of 314. Others would say 100mA TD, but what about sockets supplying equipment outdoors.....A new CU is the best measure together with the removal of the old VOELCB, no doubt.:)
If you can't convince the customer the customer to replace the CU , just the rcd, what certificate would you give (minor?) and would you justify your choice of rcd in 4) Details of departures (if you used the minor works cert)ie 30mA fitted because customer uses garden power tools - cheers:)
As I said, depends whats there.
It would be pointless fitting a 100mA TD if there wasn't any RCD present alraedy. Over protection is better than under protection IMO, If it were something like a 3036 board protected by a VOELCB and they just would not pay for a complete upgrade, I would fit a 30mA one and fill the comments box with as much info and reasoning for further upgrade as I could.
Thanks Guys
so remove and replace with A) Dual RCD board 30ma only or B) Boarb and 100ma time delayed RCD doing part rewire so new board is going in anyway.
Cheers
Reply to Earth Leakage Device in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
those old mk rcds are very fast the figure you have quoted is the maximum allowed not the typical times,I have seen mk ones trip at 9 ms , the...
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
