M
MCB
Hello all
Please help I have been doing a rewire on a house for my NAPPIT assement tt system I have installed 2 lighting circuits all ok still got an old wylex con unit at the mo
I disconectted the water heater and run a 2.5mm cable on a 15amp fuse straight to the c/u to the fused spur connected to a honeywell junction box ( hope this sounds ok so far)
Now the problem
the sockets trip when the water heater asks for power or you turn on the hot water advance button the 3 amp fuse spur also blows god confused noe!!!
on top of this I connect a new fuse wire in to the box and the earth sleeving melts from the 2.5mm 15amp water heater cable
I cant work it out as you can see I am new
I think that I should install a new eart rod with 10mm cable back to cu dual 30ma rcd disscinected every circuit and install new one by one would this be the easiest way Please
sorry spell check dont seem to work
any help be great why is the earth heating is it pfc??
Now the problem
