I've just done an EICR on an install earthed TT . The Ze on the rod was high 245 ohms , which in theory is fine as it is less than 1667 and the equation Ra X 0.03 > 50v is satisfied .
When the gas and water bonds are reconnected the Ze drops down to 4.4 ohms ,
Do I put another rod in ?
The property is in a built up area with pme available , do I get the Dno to fit pme ?
