Earth rod installation services below | on ElectriciansForums
Discuss Earth rod installation services below in the UK Electrical Forum area at ElectriciansForums.net
london
Hello guys
I have a job coming up where i will be installing x2 car chargers in an office car park (wall pods) supplied from a PME.
When installing earth rods what procedures can anyone recommend to ensure you do not go through any services below?
Site drawings would be ideal however they are not always available
If you dont want to install a rod then use 2 of the.new podpoint ones. They can be used on pme and fully comply. You can buy.them from 2 suppliers. A posted about them recently.
As others have said dig down as far as possible and go careful. Maps may help to an extent but sometimes yoi can never be 100%
Reply to Earth rod installation services below in the UK Electrical Forum area at ElectriciansForums.net
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
