Earth rods are not the only means of providing a TT system, but all of the alternative methods are going to be more expensive to install in both materials and labour costs!! Before you make any discussions on what you're going to do, try test drives in various locations within the properties boundaries to see if you can miss the sandstone.
Bentonite is fine for a lot of ground type conditions, but Marconite is by far superior and what's more, it's permanent!! It's also more expensive than Bentonite.... If you can't find a local supplier, you can always order either of these two rod/electrode enhancers from ''Furse''
If you run into trouble on this installation and need any further advice, you can always come back and ask!!
