W
westy8139
Is it okay to fit a 16mm earth wire to a galv rod without an earth pit or mechanical protection? I think I read in the regs it was ok, as long as 16mm?
Help appreciated
Help appreciated
Discuss Earth rod in the UK Electrical Forum area at ElectriciansForums.net
Galv? sure it isn't copper? how long and how thick lol, otherwise yes as marvoIs it okay to fit a 16mm earth wire to a galv rod without an earth pit or mechanical protection? I think I read in the regs it was ok, as long as 16mm?
Help appreciated
4mm might be a bit shy depending on the supply size.........my understanding is that the cable could be 4mm and does not require protection unless burried but the connection between the cable and rod must be protected against corrosion
oh dear. Reg book page 159 table 54.1 :nonod:my understanding is that the cable could be 4mm and does not require protection unless burried but the connection between the cable and rod must be protected against corrosion
nick have you seen the 4x4 green plastic boxes mate which sit above the rods? much more room and easier to fit than those things, apart from a genuine pit the green boxes are the best way forward.Here's a pic View attachment 22095
Reply to Earth rod in the UK Electrical Forum area at ElectriciansForums.net
