Earth size for TT | on ElectriciansForums
Discuss Earth size for TT in the UK Electrical Forum area at ElectriciansForums.net
TJC1
United Kingdom
Got chatting to another electrician today who said about using 16mm earth for TT. Not that i have ever had to put steak in but am i right in saying its 10mm for a TT system?
I would be happy to use 2.5 mm protected :)
I suspect any reduction of earth resistance by using larger size cable to ground (other than for reasons of mechanical protection) is minimal,driving in longer electrodes would probably help,but why go to all the trouble when the cable generally only needs to carry 30 m/amp to operate a RCD,your 10mm should be fine if your not burying
I would also be inclined to use 10mm
as above, it has more physical strength, who really wants to add mechanical protection to a cable so they can save ÂŁ5 on the job?
10mm is always on the van so it just seems like a good choice for 99% of the jobs.
Reply to Earth size for TT in the UK Electrical Forum area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
To give you some idea....with my DNO, the question "Can you see arcing, sparking or smoking?" is 3.5 minutes into the automated call answering...
