DAVE WILLIAMSON
Heres a good one ,can anyone out there inform me that if i take down an existing light fitting to replace it with an identical one and the wiring is good but the old colours (red,black,green) do i have to remove the earth sleeve and put on the yellow and green sleeve to comply with the 17th edition or is it perfectly acceptable to leave the existing sleeving. Also when doing an in line joint onto a junction box to spur off you do not cut the existing cable you strip it ,so the earth will have no sleeve as you cannot put it on (you would have to cut it to do so) is this acceptable . Just asking because where i work they say not ,but i think its ok ,so does anyone know..cheers..
