Earth terminal block | on ElectriciansForums
Discuss Earth terminal block in the UK Electrical Forum area at ElectriciansForums.net
Yes, its for an existing installation with a very awkward route, just seemed as though it would be simpler, but looking at this a bit closer, the earth's out of the service head are only 10mm?
How will the open sided connection help with an awkward route?
A line tap will allow you to connect to an unbroken cable, and be more reliable than that dodgy looking block in your OP
Nor am I daft and don't have to explain myself to anyone who answers a question with a question. And I am not doing anything non compliant. Dam & Blast I just explained myself. :eek:
I thought I was quite clear in my first post, I am trying to find a multiple connection block that can clip onto an existing cable and have other cables attached to it. I do realise that because lots of us have time on our hands it's very easy to get a bit pedantic, but I am just a simple fellow and say what I mean without a hidden agenda.
[automerge]1586954504[/automerge]
Just solder to it.
Good option, but I have multiple connections needed onto the existing earth cable.
Reply to Earth terminal block in the UK Electrical Forum area at ElectriciansForums.net
And with a duff one, it just sits there, not knowing which way to turn, but drawing considerably more than its normal run current.
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
