Earth wire loose under sink - advice | on ElectriciansForums
Discuss Earth wire loose under sink - advice in the DIY Electrical Advice area at ElectriciansForums.net
smcshaw
Chepstow
Hopefully a very quick question. Whilst looking under my sink this morning I noticed the Earth wire between the hot and cold pipes is no longer connected. I can't recall if it ever has been but I'm assuming this has come loose and I should reconnect it? If I do connect it should I take any precautions, i.e. flip the fuse off? Thanks in advance.
[ElectriciansForums.net] Earth wire loose under sink - advice
that cable (or a similar one, can't see from pic.) should connect to the cold water pipe. as close to the stop tap as practicable. generally no requirement to connect to hot.
Looking at it, it appears to have just come out of the clamp (with the red tag visible in the photo). You should be able to reconnect it quite easily if you've got a flat bladed screw driver.
if you bend that red label up, you'll see where it was connected. you can just see the edge of the cable clamp below the middle of the label. cable does not connect to the visible screw, that's the clamp screw.
Reply to Earth wire loose under sink - advice in the DIY Electrical Advice area at ElectriciansForums.net
Hissing sound from under sink Heya, So there's a hissing sound coming from underneath my sink that feeds my washing machine and dishwasher...
Seo195
J
Purpose of vent under sink? There are bad smells that come from my sink drain when I run water. On inspecting (undoing) the U-bend trap, there is...
Jimmy8127
J
