earth wire | on ElectriciansForums
Discuss earth wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
ChrisGray
i have a new light for my ceiling but my earth wire does not come down long enough to be able to attach to the actual light is this a problem or can i just use my live and neutral wires and leave the earth wire ?
would really appreciate some help please.
Thanks Hannah
as last post. extend earth with a terminal block. make sure you sleeve it green /yellow. if it's a metal fitting, the earth must be connected to the metalwork
truckster, i stand corrected. just that 90% of metal fittings are class1, erring on the side of caution . as you say, if there's an earth terminal, it's class1.
Reply to earth wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Brilliant thank you so much for your help 😊 x
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
