Hi guys bit of advice needed to save me some time and money. Earthing and bonding required in new build property. 10mm earth to be ran to gas meter to clip to gas pipe that will enter property. This gas pipe then goes to a combi boiler where I will bond all pipes at combi to the gas pipe (gas, cold water, hot water, radiators in and out) (all copper)
But when it comes to earthing the water main I come unsure. The water main into property enters the building via the blue plastic pipe under kitchen sink but as mentioned the house is piped in copper. So my question is do I have to run 10mm earth to copper side of water stop cock all the way in the kitchen or will the bonding at the combi boiler be sufficient as the cold water pipe will be bonded to earth via the earthing of the gas pipe. Hope this makes sense
Thanks again in advance !
