Dazzac
Hello all
I have a question that is really bugging me. I have searched the internet but cannot find an answer so hopefully someone here can help so here goes.......
It is to do with earth fault loop impedence. If a line conductor touches an earthed part say a washing machine, then the fault current passes through the earth conductor to the electode if TT or pme for TNC-S etc.
Question....
So we have a 32A MCB on the circuit where the fault has occurred. How does the fuse blow under these conditions if the fault is carried down to earth? How does the current increase enough for the fuse to blow? If the current is flowing to earth how can a fuse blow if a high percentage of that current is not passing through the fuse? And also the earth is totally separate from the actual conductors so I can't understand how the fuse actually blows! I hope I haven't confused things too much!! Please correct me if am wrong, i am still learning so bear with me!! Cheers Daz
Question....
