Minimum requirements for earthing a steel framed shed? 4x3m
As3000 once again giving conflicting advice..
Incoming submain 6mm TPS 2 Core plus earth.
Incoming earth with 6mm is 2.5mm.
Section 5 of As3000 states that because my incoming is 6mm my earth to shed can be 2.5mm.
However, minimum requirement for equipotential Bonding is 4mm..
Thinking if I should do a earth rod behind shed, remove incoming earth from 6mm, create new MEN link (shed technically is an out building)..
Some advice would be appreciated.
I am a sparky fyi thanks in advance
