H
hillbillie
I'm working in a warehouse, that was originally a factory. The electrics were put in in 1965 and were added to by successive owners over the next 20years and since then have been neglected.
Some of the boards have no earth so I thought I'd run some cable from the MET in the meter room to these boards. The problem is that the runs will be up to about 90 metres. Should I use the same standard that the OSG uses for bonding conductors (i.e. to ensure the circuit resistance is kept under 0.05 ohms) for these?
The earthing system for the premises is TN-C-S
Thanks.
Thanks.
