Earthing cable to gas meter damaged | on ElectriciansForums
Discuss Earthing cable to gas meter damaged in the DIY Electrical Advice area at ElectriciansForums.net
Bexley
Hi Everyone
I have just damaged my earthing cabling that connects to the outside gas meter while hedge cutting!
The cable is not severed completely but for now, I have taped up. However, what is the best way to repair this cable? Unfortunately, the cable is not long enough if I cut it before the damaged section to connect to the clamp on the gas pipe.
Is there a recommended way to fix this type of issue within regulations? I can provide photos if necessary. Thanks!
A pic might help. But in any case, after its repaired, it will need testing for continuity.
A small charge by a local sparks.
Yeah you know, cutting a hedge.
Just need crimping and sleeving. As above a small charge from an electrician.
Hi Midwest - attached at photos of both side of the cable. The sheath is damaged and interior doesn't look touched while the other picture shows a slit but it's not severed completely.
Yes, not my finest hour; I was using a hedge trimmer to cut back branches on a basil tree and the cable was nestled in at the bottom and caught up. ;o(
[ElectriciansForums.net] Earthing cable to gas meter damaged
Not only do you need to consider how best to repair it, bust also how to add mechanical protection ..........
that cable shouldn't be just lying around.
Ack Murdoch - it was British Gas who put the meter and earthing cable in, so I should complain about this incident. It should have been better secured as you said.
well ........ you were using the cutters and should have taken more care:)
I doubt you will get very far with BG .............
you need to get this reviewed by a pro.
Reply to Earthing cable to gas meter damaged in the DIY Electrical Advice area at ElectriciansForums.net
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
