Earthing copper pipes ............. | on ElectriciansForums
Discuss Earthing copper pipes ............. in the DIY Electrical Advice area at ElectriciansForums.net
Suffolk
While ripping the old bathroom fittings out I noticed that none of the pipework or fittings were earthed. Should they be earthed and if so what is the preferred method?
Is there RCD protection?
Bonding of metalwork such as pipes is usually done near the point where they enter the building or close to the meter.
Has the pipework been tested to see if it is extraneous?
The house was checked by an electrian before we purchased it and got a clean bill of health
Have you got an Electrical Installation Condition Report Certificate from the Electrician?
Reply to Earthing copper pipes ............. in the DIY Electrical Advice area at ElectriciansForums.net
If there's no main switch on the CU, then the RCD is doubling up as the main switch and everything is protected by it. If there is a main switch...
T
What plumbing tape is recommended for a copper waste water pipe Hi there, We have a leaking waste water pipe which our washing machine, boiler and...
Tellie
T
