Earthing for shed | on ElectriciansForums
Discuss Earthing for shed in the Australia area at ElectriciansForums.net
P
peteelecs
Hi all
could you tell me if I supply a shed 12 metres from house which is TNCS can I use the MET to take earth to shed or do I need an Earth Rod at shed.
Use the TNCS unless there are any services in there which would require main bonding...(not very likely in a garden shed).....again I'll say it,why does everyone seem to get all het up about earthing systems in outbuildings and yet will happily install outside lights and sockets on a TNCS without a second thought?:confused:
Depends on the load likely to be used and whether anything else like a greenhouse is likely to be tacked on in the future....for a socket and light sort of job a bit of 2,5mm will be more than enough....If a workshop/freezer/greenhouse sort of thing you may well need to work out a likely loading and choose a cable based on that.
Reply to Earthing for shed in the Australia area at ElectriciansForums.net
BTW, the LD at the house will be 1" to accommodate the 6/3 coming from the house. Will use a 1" to 3/4" adapter to neck down to the 3/4" conduit...
