A new stable block is now being wired on TT system with use of an earth spike.
As all extreneous conductive parts should be earthed I intend to earth 4 or 5 steel beams in the building.
However, each stable door and door frame is now clad in galvanised steel and each stable has a window with steel frame and bars.
Do all these parts need earthing? Having assumed they do, I have now advised customer who is insistant that they do not want earth wire every where.
Regards
SIDEKICK
Hi there.
There is no need to earth any windows or doors. Any services gas/water etc, and structural steel is enough.;)
If other, please explain
Business Name
earthing in stables
Thread Tags
sidekick,
Guest123,
