P
Piratepete
Hi Guys
A simple question.
For metal light switches on metal back boxes does the cpc have to be connected directly to the terminal provided on the front plate or can the cpc stay in the terminal in the back box (provided, of course, that there is continuity between the two via the fixing screws)?
While doing an EICR, I've come across the cpc connected in the back box only. Um?
Instructions supplied with metal fittings suggest that the CPC should be taken to the accessory terminal - but then they would say that to cover for the use of plastic back boxes.:sailor:
Pete
A simple question.
Pete
