I have connected the metallic armour of a 1 .5mm SWA cable (about 50ft run) to the met on the main CU using a 10mm earth cable. Is this a bit of an overkill or should I use 6mm earth cable instead?
What calculation applies to determine the cross section of the earth cable in this case?
Cheers!
Cheers!
