Just received in a couple of hundred 240V IP65 light fittings from a well-known manufucture (Clue: What did the lion have pulled from its paw?) and not one of the steel Gear trays are in contact (zero continuity) with the Earthing point of the fitting!
The shell of fittings are non-conductive polycarbonate, but in my mind the 'guts' of the fitting should be in contact with the Earth, be it a fly lead or an Earthing screw.
If on a lamp change the live has come out and is touching the tray, this tray will now be live (insulated from Earth as its mounted in the non-conductive body so the MCB will not trip) if someone touches the tray they will get shocked.
Am I over thinking this, or is this the way 4' lamps are now manufactured, or is this a duff batch I have?
