View the thread, titled "Earthing panels?" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
Seaplane
My installation has recently been completed and it was noted that there was a slight voltage on the panels themselves and associated roof framework. (One of the installers nticed a very slight tingle when he touched the metalwork of the panels and the scaffold.) The voltage was measured at 70VAC. The meter on DC showed zero! On the advice of the inverter manufacturer, the inverter was replaced however, this failed to cure the fault.
After much discussion with the manufacturer, the installers were advised to earth the panels and framework to the consumer unit earth point. This was done and the voltage on the panels fell to zero.
Has anyone heard of this before? Any thoughts?
Jon
Sorry, not sure about earthing system. House is 16 years old and earth from consumer unit seems to be connected directly to earth in the supply box.
Yes, the inverter is transformerless.
Capacitive charge in relation to earth due to a transformerless inverter having limited separation between D/C circuit and the earthed neutral of the A/C low voltage grid.
Array should have been earthed anyway, should have followed the guidelines in the Dti Guide.....see page 22/23. You also need to brush up on earthing systems to know when to rod or not.
My course went to great lengths to say that the array is outside the equipotential zone and doesn't need earthing. It makes you wonder if all these training provides are singing from the same MCS approval song sheet?
Another training centre that I did my WAH course was saying "oh yes, you can fit panels right up to the edge of a roof!" I pity the poor sods who follow that advice and get the MCS assessor round.
You can fit pannels that overhang the roof, you just need planing permission, which would also require wind & loading calcs.
Reply to the thread, titled "Earthing panels?" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
