earthing question | on ElectriciansForums
Discuss earthing question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
green.simon9
in a bathroom which requires supplemenrty bonding and ALL the pipes is plastic,
a-bonding is only required between bath and basin taps.
b-bonding must be visible and mechanically protected.
c-RCDs are not necessary on a new circuits.
d-bonding is only required between the earth terminals of separate circuits
Reply to earthing question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
Hi I need help with understand supplementary bonding. I know RCD is additional protection and in the even of the fault at leakage of 30mA, it...
