dekachad
Hi all.
I have searched the forum and there is alot of different answers to different situations, which confuses me. So, I will put my situation on here.
I live in rural
Bulgaria and just about to do the re-wire. Everything will be wired up as normal uk spec except using radials and not rings. The bit where I am confused is the earthing arrangement. There is only L and N coming into the house (which needs upgrading). I have found out that this is a pme neutral, it is earthed at every overhead pole. I asked a local electrician what the Bg specs were and he said just put a link from the earth pin to the neutral pin in every socket and switch ! no other earth. I couldnt get my head round this. So I am thinking to connect earth to the neutral on the supply side of the cu, drive an earth rod in and also connect to the copper pipes that supply the water in the house (the water mains are all galv steel). Does this sound right or am I off the mark here.?
Thanks.
I live in rural
Thanks.
