Earthing | on ElectriciansForums
Discuss Earthing in the Australia area at ElectriciansForums.net
A
Adebambo Adeoye
Hi Forum,
Need some advice.
I am upgrading a consumer unit in a block of flats. The Existing main earthing is by an Old conduit containment previously used to contain the old 6mm submains cables that has now been decomissioned. I need some advice as to where i stand in complying with the regs when i upgrade the old cu to a dual RCD CU. Its almost impossible to employ a TT system because the flat is on the 6th Floor.
Many thanks
Add
The installation is an old one. Over the years it appears that the old cables that appears to be 6mm cabling was upgrade to !0mm. In my earlier thread i was just trying to explain what the size of the old cabling was. The 6mm cables is not used ( has been disconnected but still on the conduit that is used as the means of earthing.
Sorry for the confusion.
Reply to Earthing in the Australia area at ElectriciansForums.net
Hi, How did you get on with the wiring?
OP - is this T&E run on the surface or in conduit all the way? Or is any of it below the surface? I'm guessing not as you were talking about...
