V
voltage
Hi all
Looking at changing some fluorescent lights in my kitchen one 4ft and one 5ft. On inspection the 4ft has a pull cord by the side of it which operates this light. The cable 1.5mm twin an earth then goes from the pull chord wired into a plug which is plugged in to a socket for its source of power.
The second light the 5ft has old black sheathing and red and black cable no earth. This light also has no access above celling cable just pokes down through so there is no access at all.
This is not right and needs earthing, my question is can i run an 2.5mm earth cable from the 4ft fluorescent to the 5ft and would this be ok ?
My initial thoughts or ideas are run a earth from consumer unit to light but this would be a bit destructive and not really ideal.
Or can you buy double insulated fluorescents which might be an option ?
Any help or alternative options would be great many thanks.
