Earthing | on ElectriciansForums
Discuss Earthing in the UK Electrical Forum area at ElectriciansForums.net
AdieB
Dorset
What is the preferred method of connecting your main earthing cables? I prefer the Earth block external to the Fuse board with links to main incomer, Gas, Water and Fuse board etc. With identification label denoting which is which. I have recently seen a rewire where all the earths were taken into / crammed into the fuse board using the earth terminal strip with no identification as to what was what. How do you do it?
Hi AdieB, I prefer the same as you, external earth block, clearly labelled and each conductor labelled, I do get overly carried away with straight cables and perfect bends, my lads always laugh at me, but I like it to look "just so".
Good luck
Always, Always to a MET earth block or earth bar. ..The only conductors in a CU or DB should be those associated with the incoming supply and out going final circuits. Apart from that, the less cables going into a CU or DB the better!!!
...But like everything else in life, i guess there are always going to be exceptions!! lol!!!
Reply to Earthing in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
I thought it was just a head with a link, rather than a fuse. Just strange that it can be so easy to pull it out. Different if it was a lid which...
