J
jase31
Found a 2.5mm spur running of a ring (no rcd, 32 amp rewireable ). The spur supplies a outhouse with a CU (10amp and 5amp mcb)
Due to layout cant get take spur directly from closer to the CU, or put in a separate circuit. Simplest seems to be to put in a 13amp fcu to protect the spur, however this may cause nuisance tripping / overload of 13amp, so something else may be a better option?
What is the easiest way to protect the spur?
The outhouse cu runs a light on the 5amp and a double socket on the 10amp (non RCD). Supply is tncs with no extraneous conductive parts.
