B
balbecdaze
I've semi-installed two 1.5kW systems onto a building being converted into 2 flats. Semi-installed because the flats don't both have an electricity supply yet - there is only one supply at present. So the wiring ends where the consumer units will be. The owner of the building is asking the builder if I can connect up one (at least) of the installs to the existing supply so he can benefit from the pre-april rate.
Am I correct in that it won't do him any good because as the flats are unfinished he can't get an EPC yet?
Or is there a mechanism I don't know about whereby as the house is being (re)built to a suitable standard (the builder has all the SAP details) the owner can use this in place of an EPC?
Thanks.
Thanks.
