Easy Roof on slate | on ElectriciansForums
Discuss Easy Roof on slate in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
K
ktech
Got another slate job coming up and been using Genius roofing kit in the past which we have been pleased with but all the same a fair bit of work involved. Has anyone used the Easy Roof on slate and what was your experience.
Brilliant, once you've to the right batten to bring the heights out. We've just used them on 23 houses on same estate so once sorted done.... Thinking of using them on the next 50Kwp system in slate. Battery thickness is the key to getting it right though
Thanks for your feedback. We just finished 100kW and I did look at the roof and think 'if this as slate it would have been a nightmare' although with easy roof it all seems more doable.
Reply to Easy Roof on slate in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Apparently so, I’ve copied and pasted below. Octopus Energy, named by the Renewable Energy Association (REA) as “the company that has done the...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
