Eaton DPU222R Terminal Lug Allowable Connections | on ElectriciansForums
Discuss Eaton DPU222R Terminal Lug Allowable Connections in the DIY Electrical Advice area at ElectriciansForums.net
USA
Hello - I'm looking to help determine how many connections are allowed on my AC disconnect terminal lugs - Eaton DPU22R. I'm not seeing anything in the documentation answering this question. I've contacted their technical support but the person did not know as well. Here is the particular documentation: https://www.eaton.com/us/en-us/skuPage.DPU222R.html
I have a Ditek surge protect that I'm looking to put on this disconnect, but I'm not sure if I can install the wiring directly to the terminal lug that has the load line of the AC or if I should pigtail it. Is there any way for me to determine terminal lug allowable connections without looking at the documentation?
For reference - the AC load lines are 6 AWG and the surge protectors are 12 AWG.
Thank you for any help
Hi
Did you find out how many connections you are allowed?
Reply to Eaton DPU222R Terminal Lug Allowable Connections in the DIY Electrical Advice area at ElectriciansForums.net
The lug to use for this purpose is the Square D / Schneider Electric QO/Homeline 100 Amp Auxillary Neutral Lug Kit for Electrical Panel/Load...
Ah OK, that makes sense. Thank you Avo.
