Eaton LZM2 MCCB | on ElectriciansForums
Discuss Eaton LZM2 MCCB in the Commercial Electrical Advice area at ElectriciansForums.net
Hello peeps
i have to set up a mccb.
I can not seem to find instructions on what each dial does on the above.
has anyone had any experience of these
many thanks
Paul
Reply to Eaton LZM2 MCCB in the Commercial Electrical Advice area at ElectriciansForums.net
Thanks Snowhead, there are 'bold' lettering NZM-1 on the unit then below in much smaller letting NZM-B1 so looks like the correct one .......thanks
Useful to know. In my case there will be 150x150mm trunking at top/bottom and almost certainly I will be using tri-rated cable, probably 70mm...
