Eco funds | Page 2 | on ElectriciansForums
Discuss Eco funds in the Green Lounge (Access Only) area at ElectriciansForums.net
The Green Deal Scheme Measures ECO (Affordable warmth)ECO (Carbon Reduction)In ECO (Carbon Saving Communities)
Low income and vulnerable households All householdsHomes in defined low income areas.
Air Source heat PumpsAir Source heat PumpsCavity Wall Insulation (part)Cavity Wall Insulation
Biomass boilersBiomass boilersCavity Wall Insulation (HTTP)Cavity Wall Insulation (HTTP)
Biomass room heatersBiomass room heatersDistrict heating (part)District heating
Cavity Wall InsulationCavity Wall InsulationDraught proofing (part)Draught proofing
Cavity Wall Insulation (HTTP)Cavity Wall Insulation (HTTP)External wall insulation EWIExternal wall insulation EWI
Cylinder TherostatesCylinder TherostatesHigh performane external doors (part)High performane external doors
District heatingDistrict heatinginternal wall insulationinternal wall insulation
Draught proofingDraught proofingLoft or rafter insulation (part)Loft or rafter insulation
Duct InsulationHot water showers (effcient)Replacement boilers (part)Replacment boilers
Hot water showers (effcient)Hot water systems (efficient)Roof insulationRoof insulation
Hot water systems (efficient)Hot water taps (efficient)Room in roof insulation (part)Room in roof insulation
Hot water taps (efficient)External wall insulation EWISecondary glazing (part)Secondary glazing
External wall insulation EWIFan assisted replacement storage heatersunder floor Insulation (part)under floor Insulation
Fan assisted replacement storage heatersGround Source heat pumps
Ground Source heat pumpsHeating controls
Heating controlsHeating Ventilation & air conditioning controls
Heating Ventilation & air conditioning controlsHigh performane external doors
High performane external doorsHot water controls
Hot water controls Hot water cylinder insulation
Hot water cylinder insulationinternal wall insulation
internal wall insulationLoft or rafter insulation
Lighting systems fittings and controlsMicro combined heat and power
Loft or rafter insulationMicro wind generation
Mechanical ventilation with heat recoveryPipe work insulation
Micro combined heat and powerGas fired condensing boilers
Micro wind generationReplacment boilers
Pipe work insulationOil fired condensing boilers
PhotovoltaicsWarm air units
ChillersRadiant heating
Gas fired condensing boilersRoof insulation
Replacment boilersRoom in roof insulation
Oil fired condensing boilersSecondary glazing
Warm air unitsSolar water heating
Radiant heatingUnder floor heating
Roof insulationunder floor Insulation
Room in roof insulationWater source heat pumps
Sealing improvements
Secondary glazing
Solar water heating
Solar blinds shutter and shading devices
Transpired solar collectors
Under floor heating
Variable speed drivers for fans and pumps
Waste water heat recovery
who said they was going to fit it ????
*alarm bell*
Fitting external wall insulation is notoriously difficult to get right, and isn't something anyone should start doing without seriously researching it, doing some test installations, and really getting the detailing right before rolling it out.
There was a company in Goole that did dozens of hours for the council without knowing what they were doing, and ended up with water pouring down the backs of the insulation because they'd got the detailing wrong at the top and around the windows, leading to severe damp problems and them having to go back and rip it all off and do it properly at their own expense, which must have cost them into the millions.
There is a reason they're classed as hard to treat houses.
if you think about it, on a lot of houses you're going to have to remove and then reinstall guttering, drainpipes, waste pipes, gas flues etc then with each window and door fitting you have to actually get the detailing right, so fitting basically new window surrounds on all windows that you're sure aren't going to leak between the EWI and the wall. Get it wrong and it's a major headache to put right afterwards.
We're contemplating getting involved, but very slowly at first to ensure we get it right if we do go down that line, and I'm pretty wary about it and the risks of getting it wrong tbh.
It's linked specifically to lower super output areas that I don't think have been allocated yet. To give you an example, last time I tried to get funding for this sort of thing with this sort of criteria it was limited to about 18 electoral wards out of over 100 and of those identified in the lower super output areas and most were social housing. It could have been changed in the last couple of months but the last I read it was going to be an extremely limited geographical market. When you think about it, it has to be targeted, I seem to remember they have ÂŁ190 million a year to spend across many measures, so about enough to do all the solid wall social housing projects in the poorest areas. It's certainly not enough to cover the 40% ish of houses with solid walls which would be in the region of 8-9 million houses.
If you're in the right place at the right time with the right tender applications there will definitely be some money to be made but I worked with the utilities for many years and everything will go out to tender, once that process has been gone through the winning tendees will deliver ECO for the utilities. I'd be surprised if the tendering isn't going on now.
Reply to Eco funds in the Green Lounge (Access Only) area at ElectriciansForums.net
A
Problem with Vaillant eco tec boiler My 10 year old Vaillant Eco Tec Boiler pump/fan occasionally turns on for 10 secs when the cold water supply...
alanem
A
P
Replaceing Immersion tank with energy efficient system I am moving into an all electric small flat which has an Elson Opal 144ltr immersion on eco...
Pepperi
P
