R
RiCkRuD3
What are the economical advantages and disadvantages of using a three phase distribution system compared to a single phase system?
Discuss Economic Advantages and Disadvantages Three Phase Compared to Single System in the UK Electrical Forum area at ElectriciansForums.net
It has nothing to do with advantages it is to do with the transmission of electricity in 3 phase format ie L1-L2-L3 or in this country what used to be Red-Yellow-Blue.
Plus it is all to do with size ie big building needs 3 phases as most of the plant ie AHU,chillers,pumps will be 3 phase load as single phase would not be an option.
So go into a domestic setting funny enough its still a 3 phase transmission but when you get out on the road it is split into single phase so 3 houses in a row on is fed from Phase L1 then the other is L2 then the last is L3. So in a house you may think you are a single phase load but you are in fact part of a 3 phase supply.
Now in a street if you lose a phase funny enough it will be every 3 house that loses its power So in other words in a domestic situation single phase is ok but when you are into commercial industrial then 3 phases.
Also noted you are from the US so not sure but because you transmit your power as 115vac then for big loads ie electric cookers then they will have a 2 phase or 240vac supply (happy to be corrected here)
As far as I know oldtimer, I believe the americans generally use the 'Edison hotwire' system, which is very much like our split phase arrangement, which is really single split phase, 2 phases of 11kv in, split single phase out with 240v between phase/neutral and 480v between the two phases. Obviously theirs is 115v/230v ish. However I assume they still derive this from a 3 phase HV network?
There nominal domestic type supply is 3 wire single phase 240V/120V. So your ''ish'' is right!! ..lol!!
Reply to Economic Advantages and Disadvantages Three Phase Compared to Single System in the UK Electrical Forum area at ElectriciansForums.net
