I
itsmrb
Hey guys
Any electricians out there? lol I have economy 7 electricity in my flat and I know that this means it runs off two tariffs - a cheap night time rate and the normal day rate. My question however relates to how it knows when to switch between the two. I have a timer clock in the meter cupboard which clicks over to the night at 11pm and day at 7am. I have two separate fuse boxes and I know that one controls things like sockets, lights etc but I'm not 100% sure about the other however I assume its the storage heaters. Looking online it seems that if you have separate fuse boxes the storage heaters are controlled separately by a different circuit and use the cheaper rate automatically. The rest works off the other fuse box which is controlled by the timer clock. The thing is I've noticed my storage heaters come on at about 10pm which seems to coincide with the timer clock (its running an hour slow). This would appear to be using the normal rate at this time but I didn't think this was possible with the separate circuits. Very confused now!
