Eddy Currents | on ElectriciansForums
Discuss Eddy Currents in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
Just a thought I would appreciate some comments on. I was at a loose end the other day and ended up watching some guy on you tube talking about Eddy Currents with regards to metal enclosures especially domestic Consumers units.
On no I hear you say not amendment 3 again, but stay with me, having seen some of the pictures of completed CUs where the installer has put the phase conductor and the Neutral through different holes, all very well you may say if the CU was plastic, but with Jan 2016 coming ever closer, I wonder how many of the less enlightened of us will still carry on doing this with the onset of all metal CUs, could be as dangerous as loose connections, what does every one think?
TBH I've never seen or even heard of eddy currents on a metal domestic DB/CU causing any heat damage or leading to a fire. I'd guess the current involved isn't usually high enough to cause the heating effect to be sufficiently pronounced. If there was a video or some pictures posted somewhere and you stumble across them please post a link here because I'd be interested to see them. Maybe someone with time on their hands could do an experiment with a steel CU and post some thermography pictures of temperature rise under different loads.
Reply to Eddy Currents in the UK Electrical Forum area at ElectriciansForums.net
Yes that is correct
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
