Just had an EDF Engineer do a de-energise/re-energise in West London
As he was doing it he casually threw in that all my main protective bonding had to be 16MM.
Nice, I'd just routed a 10mm over hill and down dale to get to the gas supply. We had a discussion, quoting regs mandatory/statutory blah blah. He rang his supervisor who said get him to uprate his supplementary bonding to 16mm!
Complete cak off course (just installed a split 17th edition CU, no need for supps) but I just went with it.
When he came back I pointed out that his supply side tails were only 16mm. His response was to threaten to down grade the supply to 60amps! told me i should be supplying the tails! He magically found some 25mm and did the job.
Nightmare getting fuses pulled in London and forget getting an isolator fitted. Spent hours negotiating through the call centre and ended up talking to an engineer via a telephonist. Literally like talking through an interpreter...
Wiltshire, no problem, isolator fitted £30ish no test results needed...
I know if I'd got the client to arrange it all i probably would have lost the job through frustration..
Add half a day admin charges?
Cheers
s
Cheers
s
