Hi There
was wondering peoples advice on these certificates... is a rented property being tns or tncs without RCD protection throughout the property a code C3 or is this by law a must?
also whats the law regarding smoke alarms for rental properties aswell?
Cheers
Dem
Hey up mate,
I dont know what experience you have of carrying out Periodic Inspections and testing, but i will guess at not too much. I am not in anyway trying to have a go at you, but the type of question you ask, is one you should know, and your question regarding smoke alarms is another question that you can find out the answer to.
I can only assume one of two things, either your are light on experience, or you cant be bothered to work it out for yourself.
Question 1. You should know that the wiring regs are not retrospective, but as you are assessing to current standards, then C3 is applicable to a circuit which requires RCD protection under the current regs, but didn't under a previous edition, as long as all other requirements of the circuit is acceptable. C3 improvement recommended, look in the notes for the EICR, it does say somewhere, that improvement recommended, does not imply that the installation is dangerous.
Question 2, Look up the BS number for Fire Alarms, within this you will see the requirements for fire/smoke alarms, with the various gradings etc. You need to use the tables and work out from the system you have, whether on not it meets the required standard, and what that standard is. There is more than one requirement for fire/smoke alarms, it all depends on the type of occupancy.
Cheers...........Howard
