EIC completion Question | on ElectriciansForums
Discuss EIC completion Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bren19
Hi, I have just completed some additional work in office that is in a building split into several office spaces all with their own meter and there is a landlord supply and meter. My question is when filling 'supply characteristics' and 'particulars at origin' is this for installation after the offices indivdual meter or from supplly coming into the building?
Thanks, but in this instance what should I put for maximum demand when I have only access to office suite I've done my work in, but non of the other offices , so I only know the demand of one DB out of several?
Reply to EIC completion Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks guys, that was my alternative thought, as I am running a cat 5 cable for Internet so it has crossed my mind to run another one for the CT...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
