daser66
Hi
could someone please explain part 6 on the schedule of items inspected.
many thanks
many thanks
Discuss Eic in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks Gutterball
This is the hand out that my tutor gave me..sorry i cant edit it.. CHROME is being a FOUR X and i cant work my GIMP!
Where it's installed mate,The bit that gets me is where says location what do you put in there.
6.0 LOCATION(S) CONTAINING A BATH OR SHOWER
6.1 Additional protection for all low voltage (LV) circuits by RCD not exceeding 30 mA (701.411.3.3)
6.2 Where used as a protective measure, requirements for SELV or PELV met (701.414.4.5)
6.3 Shaver sockets comply with BS EN 61558-2-5 formerly BS 3535 (701.512.3)
6.4 Presence of supplementary bonding conductors, unless not required by BS 7671:2008 (701.415.2)
6.5 Low voltage (e.g. 230 volt) socket-outlets sited at least 3 m from zone 1 (701.512.3)
6.6 Suitability of equipment for external influences for installed location in terms of IP rating (701.512.2)
6.7 Suitability of accessories and controlgear etc. for a particular zone (701.512.3)
6.8 Suitability of current-using equipment for particular position within the location (701.55)
7.0 OTHER PART 7 SPECIAL INSTALLATIONS OR LOCATIONS
7.1 List all other special installations or locations present, if any. (Record separately the results of particularinspections applied.)
http://www.electriciansforums.co.uk...83-eic-bs_7671_2008_amd3-2015_model_forms.pdf
Download it, Print it, Read it.. and Tatoo it on your Arm or Leg
Gasp!!Hi
many thanks
Reply to Eic in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
