EICR, ability to fill out | on ElectriciansForums
Discuss EICR, ability to fill out in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sparky1690
Is there a definitive answer on whether or not if you have 2391 then you can fill out the new EICR????
only asking as few of us are out with UK & were told we needed to attend a one day cse BUT now being told we have "grandfathers" rights as it were.
Any help will be appreciated.
Cheers.
you don't need 2391 for eicr's. as long as you are competent. having the 2391, however , would go a long way to proving your competence if the brown stuff were to hit the fan.
thanks for that, both of us hold 2391 already, just as i said someone told us we needed a one day cse BUT the form is self explanatory.
much appreciated.
You don't have to have ANYTHING except competence to conduct EICR's, which is a bit odd as you could do your 17th today and then do them.
Reply to EICR, ability to fill out in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
That's a glass half full thought 🤔
2 3
