What is the case in if you carry out an EICR and you cannot get to the connections of gas/water bonding to get a reading?
The gas meter is outside but I see no bond to it. I cannot find the water stop cock. There are a few GY cables at the MET and I guess I could disconnect the cables and long lead on to the pipes themselves and test each cable to see the lowest reading to see if they are below 0.05?
There is no cross bonding at the boiler.
