EICR Code what do you think | on ElectriciansForums
Discuss EICR Code what do you think in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Cardiff
Industrial workshop, 40amp mcb in DB, non armoured rubber cable connected in comes out of steel tray and runs across the floor against wall, then behind some fork truck racking and has a 32a RCD outlet box laying on floor loose to connect the welder to.
Which code?
Reply to EICR Code what do you think in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
